Repetitive strain injury logbook
Repetitive strain injury leads to $6.5 billion/yr in workplace compensation claims in the US alone (van Tulder, 2007) and causes something like $1 trillion/yr in lost productivity globally (something like 1/100th of the entire world’s GDP!)
And yet, there seems to be almost
It’s interesting that a situation can occur where a common workplace disorder , and yet there is a great paucity of basic research and total lack of understanding of the mechanisms and etiology
Evidence also suggests that the pres- ence of two or more risk factors can have a highly synergistic effect; e.g., workers who per- form repetitive and forceful activities have higher rates of hand-wrist disorders than those who perform either repetitive or forceful activi- ties alone (34 – 36).
https://scholar.google.ca/scholar?hl=en&as_sdt=0%2C5&q=repetitive+strain+tendon+healing+rate&btnG=
In acute injuries, the process of tendon heal- ing is an indivisible process that can be categorized into three overlapping phases for descriptive purposes. Tendon healing can occur intrinsically, via proliferation of epitenon and endotenon tenocytes, or extrinsically, by invasion of cells from the sur- rounding sheath and synovium. Despite remodeling, the biochemical and mechanical properties of healed tendon tissue never match those of intact tendon. Tendon injuries account for considerable morbidity, and often prove disabling for several months, despite what is considered appropriate management
Biology of tendon injury: healing, modeling and remodeling
P. Sharma1 and N. Maffulli2
Really good paper
When throwing away q tip strong pulling feeling pinkie knuckle pad, palm side, on right hand
Sept16- screwed up mouse hand by browsing digikey. I guess I didn’t take enough breaks. pinch pain above wrist and tingling in fingertips
While I found the advice from the regular (seemingly more sports-focused) physiotherapist helpful, I wanted to know a bit more about what was wrong with my hands - I wanted to talk to an expert in hand RSI.
I found an occupational therapist in town that seemed to have good expertise - actually, I found two, but the first did not reply. While I had pain on the days bracketing, I did not type much before the appointment, and presented symptom-free.
Contrary to the appointment I had some 8 months ago, the test involving tapping on the wrist (I believe this is called Tinel’s sign) did not cause numbness and tingling to propagate up my hand - to the contrary, there was no response at all. None of his tests were positive, starkly contrasting as well with the previous physio appointments ~6 months ago, where most tests clearly induced dull pain.
The “Q-tip” nerve glide pain was nonexistent at this time -
I mentioned forearm pain and pain in the palm - he seemed confused by the palm pain.
I had a small amount of pain when gripping the grip-strength tester.
The therapist’s suggestion was that I previously had both tendinitis (tendinopathy) and carpal tunnel, but the carpal tunnel had now resolved.
He recommended the following regimen (“since you aren’t currently in pain”). I don’t think it’s a good idea for other people to follow this blindly - he was careful to point out
  • 5 lb weight Table edge front curls back curls 8 - 12 reps - pain free arc
My arms both currently have a lot of weakness pulling the weight up
foam Ball squeesing, hard, same reps, once per day, both hands, don’t over do it
Ball I can close strneth
Pulling exersizes
He also stressed that there should be no pressure on wrists while typing.
Accuracy of Provocative Tests for Carpal Tunnel Syndrome
10.1016/j.jhsg.2020.03.002
Great paper.
Here’s an observation: Before writing the above comment, did the “Q-tip” nerve glide. I did not have the symptom I reported before - a dull “stretching” feeling in the pads of the last two fingers - in my right hand.
Now, after writing it, my right forearms are feeling poor, I have tried it again - and I have the symptom. Clear, unmistakable.
This is not really very meaningful, but it’s interesting.
Tried a cheap pen tablet. Haven’t got the settings and palm rest set up in a comfortable manner yet, but some people say it works for them.
Scrolling a mouse is one repetitive action. Push-to-scroll features (autoscroll)
I also bought an MX Ergo trackball mouse for work, though I’m a bit concerned that my thumb will get worn this way.
spacemouse-like methods
Up arrow - enter for scripts, replaced with ‘gravekey’, seems to work well.
I often take my hands off the keyboard to move the arrow keys. I don’t really have a modifier key
Backspace is another issue
I (along with other people online) am surprised that logitech designed the k860 with such a prominent wrist rest - the conventional wisdom I am aware of is that your wrist shouldn’t be in contact with anything.
The only concern I have when using it is that the numberpad makes the board a little wide, which many of the microsoft sculpt boards don’t have. I haven’t actually had any issues with this in practice though.
The keyboard is also significantly higher than a standard board, so you might need to be careful with your desk height.
Logitech have an ergo setup guide online for this specific keyboard which is helpful.
Edit: after ~4 months using a K860 at work and at home, I’ve had no issues with it. The mouse distance has not turned out to be a concern for my workflow.
home row (hjkl) arrow-keys is something I might want to get used to.
There are lists of assitive or accessible- mouse options.
Talonvoice
Found a video where I’m struggling with RSI in the right hand in june 2020
June 29 - left arm, right arm is fine, after abiut 3 days of doing EPU python. Pain is in the forearm, about a quarter of the way down, and the inside palm is tingling aa bit.
Pain at the right joint,
carried heavy groceries and heavy laptop bag on shoulder and hand
Aug 8 - had to stop at 8 pm, didn’t type hard, right wrist and forearm cold pain;
Aug 9; left palm, pad of pinkie and the finger beside it
Forearm
Aug 10: fairly bad but mad it through the day. Both hands but mouse hand far worse. sscrolling mousewheel but also page
Shooting numbnews if I hunch shoulders and touch nerve under arm
Could I hire a typist? Might keep me focused too…
Aug 13: very bad. Worst in 6 months. Didn’t type much today but I overdid it last week. No heavy lifting recently. shoulder numb, muscles, etc
severe pain when closing finger at inside wrist-forearm, also behind the arm
aug 15: so, so bad. bought ergo keyboard. just made it through the day.
Really just want to learn if there are excersizes
Nerve glides
He says it’s tendonopathy + carpal tunnel before but that test was negative now
Aug 24: worked till 1 the night before. Programmed from 9:30 to 5 pm, right wrist got progressively worse over the day.
“but came up with scheduled breaks and also changed my posture”
Split and ortholinear did nothing for my RSI
“Perform two-key commands with two hands; rather than stretching to reach shift and another key with the same hand, use both hands”
Brown CS: Preventing RSI
https://news.ycombinator.com/item?id=8486013
I wonder if something like the razer orbweaver, for the left hand, wouldn’t be a good idea, particularly because of the thumb that could be used for scrolling.
foot pedals, can cause rsi themselves though
learning Vim might be a good idea to minimize keystrokes for general editing tasks
or some other advanced multi-cursor
tried out eviacam. definitely will see my neck getting sore.
Because I really want multi-monitor, glasses-based solutions look like the best options. There are a few projects out there that use IR
Eye tracking seems like the ‘right option’. eyes don’t have much mechanically going on, they move a lot and repetitively anyway
https://www.yorku.ca/mack/cogain.html
really interesting work at york. essentially parity with mouse is found when “The Eye+SPACE Key (ESK) technique allowed participants to “point” with the eye and “select” by pressing the SPACE key upon fixation.”.
However, eye fatigue was a concern (3.5). Participants complained that staring at so many targets made their eyes dry and uncomfortable. Eye fatigue scored lowest among all the questions. Participants gave eye tracking a modest favorable response overall of 4.5, just slightly higher than the mid-point. Discussions following the experiment revealed that participants liked to use eye tracking and believed it could perform similar to the mouse. Of the three eye tracking techniques, participants expressed a preference for the Eye+SPACE Key technique. Concerns were voiced, however, on the likely expense of eye tracking system, the troublesome calibration procedure, and the uncomfortable requirement of maintaining a fixed head position.
