Life
this is one of those deeply personal pages. Before reading this, please see the About page.
Punctuality
I set multiple alarms on multiple devices (phone, physical alarm clock, pebble), spaced 10 - 20 minutes apart, starting maybe half an hour before the deadline when I need to get up. This way, if I fall back asleep, I’ll get kicked back up again - in a way that the snooze button doesn’t seem to do. Vibrating pebble seems to work well as one of the devices.
I get a lot of mileage out of Google Calendar (for personal items) and Outlook Calendar (for work items), but I do often miss the notifications, which don’t mandate acnowledgement. My best strategy is to every few days copy to Android’s default Clock app and set an alarm with a label corresponding to the event. Can use multiple different alarm tones/vibration to denote different priorities. I always set two alarms:
  • If I need to commute there, I set an alarm about 40 minutes before the time I expect. I usually only have a few things set up per day. If I don’t need 10 to 30 minutes early (so I can use the washroom, finish up what I’m working on), and one at the time of the event.
My Pebble used to fulfill this function, with the ability to set 8 (unlabelled) with the advantages of always being on my person (sometimes I put my phone down and not in my pocket then miss an alarm) and not bothering co-workers, but it’s since died.
Having timers in a physical location of a task is useful. I bought a 12 pack of timers.
One task I have is to put my dosimeter away. I don’t know how long it’ll take. I set an alarm for am hour. I might be in the middle of a task when the alarm goes off. So, an alarm app with auto-repeat is great.
I set up a repeat vibration-only alarm to remind me to drink or eat every few hours. It was only moderately successful.
Transportation
Think about backup plans: what if your car doesn’t start. How long will it take for the next bus or a taxi to arrive
For the bus, I got up at 6:20 one time, left immediately, just missed the first bus, and still needed to call a taxi at around 7.
Sleep and waking up
I’ve always had a lot of trouble falling asleep, even from a very young age (though then my bedtime was quite different, of course). A good friend of mine who has a similar persuasion (similar set of hobbies, that is) has professed the same thing to me - unable to sleep because of thinking of projects that seem important (in fact, he lost his job as a result) and a few other acquaintances have reported the same problems.
Anxiety, ruminating thoughts.
Waking up
Saskatoon can be dark in the winter when getting up.
A work colleague mentioned that he had once set up a light in the window to solve this problem.
I bought a Hue bulb. Bluetooth, had to keep re-activating the.
Lamp attempt 1
I really resented needing needing another IoT device just to turn on a lamp.
300 watts of lighting on a Canadian tire light timer.
However, over a period of a few months, I found this didn’t wake me up nearly as reliably as the Philips Hue wake-up routine. I think the reasons are:
  • The Hue fades in slowly; according to Reddit does something . Used to have it set 10 minutes from 6:35 to 6:45 AM, now
  • Probably most important, the bulb is on the ceiling and well-diffused, lights up the whole room; I can’t roll over and shield my eyes.
  • Color temperature is more sunlight-like
Seem to reliably not get out of bed at appropriate time if the hue wasn’t set.
I hate that I will need an account and a hue hub just for a wake-up lamp, but I relented and I now have three Hue warm white 800 lumen bulbs and a Hue Bridge. So far it’s woken me up.
Parameters
In case of power failure, at least one battery powered device
Hue Fade in from 6:00 to 6:30 AM.
Falling asleep
I had one progressive muscle relaxation audio CD which worked incredibly well for a few sessions at the time, which I’ve since lost - slowly tensing and releasing muscles . I’ve tried various ad - university mental health pages are good places to find free sleep audio tracks.
Can get into a vicious cycle if you need to get up early.
A sleep counselor I’ve been going to has recommended ACE, which has been pretty effective. The most effective technique I’ve come up with so far is:
  • Complete a round of ACE, which finishes with the commitment: “Full attention to the task at hand”. Setting a timer on my watch for about 8 minutes seems to be a good way to remember to focus.
  • Find a part of my head or face that’s tingling a little bit, and try to make that spread.
  • If you get distracted and stay awake and then realize - don’t get mad at yourself or try to process that, just directly return to trying to fall asleep.
Two Minute Rule.pdf (33.5 KB)
ACT - Dropping Anchor (Russ Harris).pdf (262.7 KB)
Brain & coping mechanisms
As a scientist (and, obviously, as any person), your brain is a tool which is at the nexus of all activities. Obviously, a lot of focus is put on information to fill your brain with, techncial skills, time management. But it means being calm enough to interact with people and run experiments effectively; it means being able to shut your brain off when you need to sleep; being able to control your mindset and ; knowing when to work late and when to start fresh, picking up on warning signs in yourself. Alex dainis don’t science hungry.
Many otherwise superbly technically skilled people at work have had their opportunity to produce good work in the organization impaired or removed altogether because they could not maintain their sanity (or could not maintain appropriate) relationships.
Other people to prove themselves they work until they are unable to function,
I enjoy working late and fooling around, and I have sometimes found the “bonus hours” I can create between 7-10 pm (or later) can be my most productive. But it must be recognized that this is, in some sense, a choice. Easily argued that the most important scientist of the 20th Century was Bardeen
The book’s opening and closing chapters address the following questions: Why are some scientists, despite obvious achievements and stature, less well known than others? What makes for “true genius”? and What is scientific creativity? The authors believe that, in general, personalities less flamboyant and eccentric than, say, Einstein and Richard Feynman fail to register on the popular cultural radar because, historically, we have associated genius with certain psychological and behavioral traits that originated in the Romantic Period myth of the genius as extravagant, absent-minded, “superhuman,”—“unbalanced, a bit mad perhaps, a recluse,” and “possessed by (rather than endowed with) creative power.”
Hoddeson and Daitch use Bardeen’s life and work as the basis for a more nuanced profile of “real geniuses,” whom they believe to be characterized by such qualities as perseverance, motivation, passion, talent, confidence, focus and effective problem solving—characteristics and skills that can be nurtured and developed. This more egalitarian portrayal offers hope for all those who may contemplate a career in science, even those who, like Bardeen, are modest and unassuming.—
https://www.americanscientist.org/article/john-who
Metacognition
Something I’ve noticed with regard to mental health is that it’s easy to get wires crossed and misattribute why you are feeling a certain way. Is that person really doing something to make you grumpy, or is there an endogenous stressor that’s making you more sensitive to otherwise innocuous behavior?
metacognition.
2 minute rule. If I’m stuck ruminating or anxious about something, I set a 2 minute timer on my watch. Close my eyes, sit down, and do nothing to resist the thoughts, think as much as I want about anything, until the timer goes off. This usually helps snap out of things.
Healthcare
Allergies
I’ve had issues with my nose running continuously in the fall to winter season.
I started with diphenhydramine, definitely worked but I would get nosebleeds and all sorts of negative symptoms, especially if I took it two days in a row. Tried out a few other options, Loratadine (Claritin) didn’t prevent the symptoms. I now take Ceterizine hydrochloride (Zyrtec or generic) 5 mg (half tablet) upon symptoms, full tablet (10 mg) if they persist after a half-hour or so. I’m okay with this, except that it claims to be non-drowsy but it does mess with my brain significantly.
I understand there are injectable antihistamines which might be something I want to look into.
Misc
[details=“Antiperspirant”]
"Apply antiperspirant twice a day (in the morning and at night). Why? At night, you sweat at a slower rate, which allows more antiperspirant to sink down into your sweat ducts. "
Just learned about the difference between antiperspirant and deodorant. Especially if I’m trying to avoid driving to work, in the middle of summer, . Tried Old Spice pure sport combination antiperspirant. Worked well, dry all day, except it’s almost impossible to remove at the end of the day. Switched back to the deodorant-only Old Spice classic. Wearing an undershirt is sufficient to prevent stains, and this is what I’ll keep doing.
General
This text will be hidden
Other gross hygiene stuff
  • certain areas.
Your header here! (Click to expand)
Your content here... > markup like blockquote's should even work on github! more content here...
Gilbert’s syndrome
Eyes were yellow, bilirubin levels were high (25 vs typical 22), but doctor suggested Gilbert’s, other liver values were normal, not dangerous but if I get unwell those levels might spike
Important dates
Car insurance renewal Jan 30th.
Paying taxes
I use ufile. In 2022 I submitted the tax return on March 5th.
Use automatic import from CRA. Tried on March 1, 2023, T4 hadn’t been updated in CRA yet.
I made an appointment to get the HPV vaccine after Cara Santa Maria’s fucking chilling story of cervical cancer on the SGU, and because I’m below age 27 cutoff. Talked to doctor, they said to contact Public Health directly.
They said it’s three shots, $800 per shot.
Later:
This person at SHA was in error, it’s $250/shot. Put it through the HSA insurance.
TWiV 1159: Eliminating cervical cancer, and endometrial immunity
really nice podcast, great information on HPV oncognesis. The mechanism of HPV into cancer is actually really well understood and direct! There’s also HPV skin cancer on the hands!
Started leaning into apps. Amazing how much of a difference a good user interface can make. Really powerful tool for getting your brain to work properly. Take it for granted how much work goes into making e.g. ynab.
Now using
  • Structured for time management
Haircuts are a fairly substantial expense for me - with tip it’s easily $30 to $40/mo. It’s also pretty clear that if I let my hair grow out a bit people treat me like I’m insane.
I can actually do a passable job with just the trimmer head on my Braun 3040s and a pair of scissors for the front. Set up a tripod with a camera facing the rear of my head so I can see what I’m trimming. Works well just after showering, haor still damp. Need to re-moisten if it gets dry. The key to not making the front scissor cuts look sharp and abrupt is to have the scissors facing almost straight up, just a slight angle to the hair, then take many small nips out of a section.
Do it in the bathroom. I clear the counter as much as possible, remove toothbrush and rug
Separating light and dark clothing is for chumps. However, I lost several pants and shirts to shrinking and wrinkling of the collars to such a degree that I couldn’t wear them.
I have started separating my button work shirts and pants from the rest of clothes. I run one load with all underlayer clothes, which I wash and dry on Normal. Then I wash (in the winter, long-sleeved work shirts) ~~ and the pants separately~~ (seems to be fine running them together) and each on Delicates. Then I hang the damp shirts and pants in the closet to air-dry in a good shape.
I had some issues with pants air-drying into a stiff set; but this seems to have gone away.
Since January I use YNAB to track expenses.
I’ve been scratching my head trying to figure out where the money is going.
Looking at the last 3 months, payments under $100 account for $3000, about $1000/mo; and the average payment is $23. Small charges build up, surprising nobody.
Dentist suggested that it might be easier to floss at times other than in the evening when brushing teeth. Indeed, flossing just after eating at work when I still have some energy seems to work great.
thought I would prefer the flosser string, but the plastic picks are actually much nicer once you get some practice.
After about 45 mins, the “runners high” (a burst of feel-good endorphins) kicks in. I then find my mind usually begins to become strangely clear at the 45 min mark and beyond, and I have almost no thoughts on my mind at all - except continuing to notice my breathing and the scenery around me.
this! biking seems to have that effect.
should try taking antihistamine in the evening before going to bed.
split this topic up
make a topic for Attention. cat S22.
https://chromewebstore.google.com/detail/unhook-remove-youtube-rec/khncfooichmfjbepaaaebmommgaepoid - good!
Plan to Eat - use inverse. select all staples and add to shopping list, then walk around and.
Allergies
Ceterizine hydrochloride (Zyrtec or generic) 5 mg (half tablet ) upon symptoms, full tablet if peraist, mildly drowsy
Loretadine not powerful enough
Later:
switched to 5 mg desloratadine.
It seems to be effective enough. It takes a bit more planning than Zyrtec; I don’t feel like it quashes as quickly; may need to consider taking it the night before - but I haven’t noticed any mental impacts.
“Desloratadine starts to show its effects after 75 minutes . Its effects can last up to 24 hours. It reaches its peak level in the body after 3 hours. Desloratadine has a long half-life of 27 hours, which means it takes around 27 hours to eliminate half of the amount of the drug from the body.”
Desloratadine - Uses, Side effects, and FAQs.
“Desloratadine is a highly selective peripheral H1 receptor antagonist that is significantly more potent than loratadine .”
Results: At 4 and 8 weeks after randomization, subjects taking continuous DL showed statistically significant improvements in VQ-Dermato Global Index score (P = 0.001 and P = 0.016, respectively) and dimension scores for daily living activity, mood state, and social functioning vs subjects taking DL PRN. Improvement in DLQI score at Week 4 was also significantly greater with continuous DL (P = 0.001).
Conclusion: Continuous daily therapy with DL 5 mg is a better regimen than PRN treatment to maintain or improve QoL in subjects with CIU.
also, what a case of xkcd “effect sizes so big you don’t need statistics”. P = 0.001 !
continuing to have trouble waking up. much better now that I’ve got the hue firing reliably, but still not 100%. may need to tweak the timing
this is despite the Mi Band 6 vibrating - I tend to dismiss it pretty easily. not wearing the bangle 2 while sleeping because the strap it came with is uncomfortable during sleep. according to reddit,
One problem is that I turn off my second alarm clock, a google home which I’ve put some distance away from my bed and which fires again 20 minutes later, before I leave as a curtesy to my neighors. I have this set so that if I go back to bed after acknowledging it, I’ll get woken up.
what I really need is something that
last tuesday was a good example of what I can do. went to was highly motivated to get up and work on stuff.
but, on wed and tues, I basically lost it - my judgement was screwed up, behaving oddly.
putting a timer in the shower works well to prevent
images|500w
I bought a 12-pack of timers from Amazon and I’ve gotten a lot of mileage out of them in general.,
https://grocy.info/ this looks very nice compared to plan2eat.
  • the cost of meal feature is something I was missing.
  • also want the ability to have the same item in two different locations (allergy meds in backpack, and in). grocy has location tracker which is very nice.
  • also, for the “chores” feature, “due date rollover” is exactly what I was looking for. love this!!!
  • that’s good for recurring, predictable chores. I like how there’s an ‘overdue’ section. I think I’ll probably not use this for actual one-time tasks though, because
    – no support for “subtasks” or “prerequisites” like redmine, which helps me break things down
    – no support for setting “priority”
Intranasal steroid sprays are safe for long-term use, and there is little evidence to indicate they cause significant systemic side effects.
…1. ⁠Synthetic underwear washed in cold/cool water. Odor gets trapped in the fabric. They smell fine when clean but as you wear them they warm up and start smelling rank. Wash them in hot water and add a little white vinegar.
https://www.reddit.com/r/shittyaskscience/comments/1hxvikl/why_do_i_smell_like_shit_when_i_sit_down/
