Notes on ultra-high vacuum technique
this is intended to be a public wiki. Please feel free to edit!
ConFlat
The mechanics of conflat are discussed in Lutkiewicz and Rathjen 2008
Flanges made from aluminium are also available, using hardened coatings on the knife-edges, which are exclusively usable with aluminum gaskets. This is sometimes used for the greater thermal capacity. Unless there is a seriously compelling reason to, I would suggest avoiding aluminum gaskets.
In the case of aluminum . Copper gaskets have a work-hardening property that makes it retain a good seal preload even in the case of temperature fluctuations and baking.
In some areas at our facility, equipment (cameras, lights, etc) may be mounted using brackets to the outside of flanges using the flange circle’s bolts or studs. This is convenient as it does not require. However, for the reasons discussed below, great care must be taken when modifying this kind of mount. The distance . groove grabber.
Many . Metal-to-metal. leave some gap between the faces so any leaks can be re-sealed.
dd
gasket stays in the non-rounded punch face. ca
The forces involved in bringing some flanges metal-to-metal may exceed the yield strength of stainless steel bolts. See () for more information on this topic.
Reluctance to use anti-galling compounds for fear of contamination, seizing stainless fasteners is very common.
Copper gasket clips
gasket removal tool
Suppliers and manufacturers
kimball physics
To add
Vacuum hackers warning to samy
Bolts that show signs of deformation should be discarded. Some vacuum workers do not attempt to reuse 1.33" conflat flange screws because a significant number are distorted after one use.
https://www.mtm-inc.com/proper-torque-for-conflat-flange-bolts.html
Books
The Physical Basis of Ultrahigh Vacuum,
P.A. Redhead, J.P. Hobson, E.V. Kornelsen,
American Vacuum Society Classics,
American Institute of Physics, 1993
Foundations of Vacuum Science and Technology,
Edited J.M. Lafferty, John Wiley & Sons, 1998
Handbook of Accelerator Physics and Engineering, A. W.
Chao, M. Tigner, World Scientific, 1998
CAS CERN Accelerator School : Vacuum Technology,
Edited : S. Turner. CERN 99-05, 19 August 1999
Handbuch Vakuumtechnik, M. Wutz et. al, Vieweg,
Braunschweig/Wiesbaden, 2000
Journals:
VACUUM
Journal of Vacuum Science and Technology (A)
Nuclear Instruments and Methods (Section A)
https://indico.cern.ch/event/414191/attachments/845420/1176230/a01443s3t3.pdf
http://www.ece.ualberta.ca/\~schmaus/vacf/index.html Vacuum basics.
http://www.ece.ualberta.ca/\~schmaus/vacf/vacsys.html How to operate a diffusion pump.
http://www.vacuumlab.com/articles.htm More advanced vacuum information.
http://shop.store.yahoo.com/vacuumshopper/oils.html Rotary vane and diffusion pump oils.
Definition Pressure Boundaries
mbar
Low Vacuum LV 103 − 1
Medium Vacuum MV 1 − 10−3
High Vacuum HV 10−3 − 10−9
Ultra High Vacuum UHV 10−9 − 10−12
Extreme Vacuum XHV < 10−12
2.1 Basic notions
2.1.1 Ideal Gas Law
A rarefied gas which obeys to the ideal gas state equation can be defined as ideal.
Table 2.1 Degrees of vacuum and their pressure boundaries from Lafferty
john o’hanlon a user’s guide to vacuum technology
high vacuum technology, a practical guide
vacuum engineering holkeboer, jones, pagano, and santler
Varian vacuum training manual - Basic Vacuum Practice, Varian
This event is
displayed in Figure 4.16. Shortly after the second sudden increase the QCM failed.
QCM’s are known to fail once too much mass is on the deposition surface. This was
expected to happen eventually. QCM failure is marked by a constant reading (flat
line). The behavior of the QCM before failure is consistent with the film fracturing.
As the film fractures, it delaminates from the surface of the QCM and causes sudden
jumps in the frequency reading (Westley et al. (1998); Pugh (2003)).
https://trace.tennessee.edu/cgi/viewcontent.cgi?article=2364&context=utk_graddiss
Establish a bag stickering procedure to ensure that non-vacuum-cleaned parts do not get mixed in with vacuum cleaned parts, like this:
https://www.hmark.com/product/clean-label/
like surgeon stickers.
At the 1st International Vacuum Congress (IVC) in 1947 Nottingham suggested that the limit to
the lowest measurable pressure was not caused by the pumps, but by an X-ray effect in the IG: he
proposed that soft X-rays, produced by electrons impinging on the anode, released photoelectrons
from the ion collector; this photocurrent was indistinguishable in the measuring circuit from the
current due to positive ions arriving at the ion collector. This hypothesis was soon confirmed by
Bayard and Alpert [3] who reduced the size of the ion collector from a large cylinder surrounding the
other electrodes to a fine wire on the axis of a grid anode. This elegant solution reduced the lowest
measurable pressure by a factor of 100 and is still the most common design in today’s commercial IG:
the Bayard–Alpert gauge or just BA gauge.
When the X-ray limit was pushed down in this manner, another component to the background
current became evident. Electrons hitting the anode may ionize molecules adsorbed on the surface
with a subsequent release (Fig. 12). Ions generated in this manner cannot easily be distinguished from
those generated in the gas phase. Since a grid structure of a BA gauge has a surface area of about
10 cm2
the amount of adsorbed molecules can be rather high (1016). Therefore it is important that the
grid structure be very clean. Two measures are usually taken to cure this problem: the grid is cleaned
by electron bombardment after the gauge had been exposed to high pressures or the atmosphere, and
the electron current to the anode should not be too small during operation so that the gauge is
continuously ‘self-cleaning’.
I’ve just come across a paper that’s really tickled me - https://www.osti.gov/servlets/purl/555564
This paper presents a timeshared rough vacuum system. I don’t know if it would be practical to implement this anywhere around here, and probably folks around here are already aware that this is possible, but I found it a pretty nifty concept.The key is that modern turbopumps can tolerate a much higher foreline pressure than the base pressure that a good scroll pump can achieve (~10 torr >> ~100 mTorr).In this paper, they connect the forelines of 4 sample load-lock chambers and 5 beamline turbopumps to a single scroll pump via two valves. They also add a “ballast tank” made out of a big chunk of PVC pipe. They add a TCG to the ballast tank with the setpoints configured such that, essentially, the scroll pump only turns on when the pressure rises above 1.5 Torr. The results are that they only actually need to run the pump at total of 4 hours per month.
“The large ballast volume, combined with the low leakage rate of the beamlines and sample chambers and the high foreline pressure tolerance, permitted only occasional pumping of the ballast volume, greatly reducing the operating time of the scroll pump”
The advantages are:
  • No vibration 99.4% of the time.
  • The scroll pump essentially never needs the otherwise annual tip seal service.Of course, lots of disadvantages; a few obvious ones might be loss of redundancy and separation of systems, contamination from one region could propagate into another. The foreline pressures are allowed to rise, so I’d guess the base pressures in the turbopumped regions would be higher. Also, the vacuum load / leak rate from all the chambers needs to be sufficiently low for this to even be achievable.
coworkers raised some important operational concerns; how often are coupled chambers vented
if there’s a leak, could be catastrophic across many systems - would want lots of automatic isolation valves in lots of places
I’m told this technique is used on some Phillips TEMs.
Two such systems in use here at work, both on upstream / mono tanks - big foreline tanks. Say scrolls have lasted decades.
Scroll pumps produce a lot of Teflon tip seal dust. When there is no purge gas and the system is not vented often, this can accumulate in the scroll. This dust can also be found a few tens of centimeters up the foreline. Counterintuitively, there can also be a fair amount of moisture in the centimeters after the foreline.
I’ve seen a filter kit (add mcmaster-carr unit #) used to prevent this dust from
put plastic hose type here
I’ve needed to spec out some bog-standard low-conductance valves - something you’d use for roughing or vent line applications. targets were:
  • direct-acting solenoid (not pneumatic). This excludes a lot of good options that you’ll usually find under the keyword “inline poppet valves” and limits the conductance / port sizes that you can expect.
  • elastomer seat is fine (don’t need all-metal)
  • but still with some sensible pedigree for high vacuum (something I’m comfortable sticking on the side of a UHV chamber - basically, not something that looks like it came from Tractor Supply)
  • as commodity as possible - not necessarily dirt-cheap, but something that I know I can get 10 of without waiting a year lead-time, and where I trust can get replacements for years
Maybe I wasn’t looking in the right places, but I really didn’t find all that many options - especially from the big names in vacuum - and I’d be interested to hear what other folks use. But here’s what I came up with:
Honorable mention to Burkert (distributor: Tameson); you can buy some of their valves vacuum-clean, e.g. 151389. ~$500 USD.
https://emvogil-3.mit.edu/~weiss/LIGO_beamtube_baseline/LIGO_beamtube_summary_and_baseline.pdf
PEEK vacuum compatibility
Haru over at the the Hackers said he had issues with PEEK at UHV, even after baking at 200 C.
https://cr4.globalspec.com/thread/79137/Cleaning-PEEK-to-UHV-Standards
Thanks for all the suggestions. I think we’ve pretty much decided on a wash in alcohol, several stages of demin water ultrasonic & a vacuum bake at below the glass temperature for PEEK, around 100°C.
The PEEK parts did not give any problems.
Our systems are working at 10^-9 or 10^-10 Torr & have been in use for over a year with out any problems. As mentioned before, these systems are continuously pumped so any outgassing might not be noticed.
UHV process traveller for LIGO
Wrap & Tag vacuum clean
parts per E960022-A
E960022-v24 has bagging and labelling description
When you think of ion gauge filament burnout, I’ve thought about this in the context of chemistry (tungsten oxidation) or poisoning. However, there’s another failure mechanism that can occur even with an inert gas and a chemically unreactive noble-metal filament: thermal shock.
https://link-springer-com.cyber.usask.ca/chapter/10.1007/978-3-540-74433-7_2
Baker and Staniforth (1968) [1-19] presented an article, “The development of an adsorption foreline trap suitable for quick cycling vacuum systems.” “By using 5–10 mm diameter activated alumina balls in an inline column geometry trap the adsorption of water vapor during pumping was reduced to a minimum. With this material and trap design unlimited repeat pumpdown cycles to less than 100 millitorr were possible on a typical 116 liter volume chamber. The pump-down time in this case was extended from 3.5 minutes without the trap to 6.5 minutes with the trap.”
mcmaster-carr 5077T143 fpm seal
In the last years, efforts have
been undertaken to develop a ‘cold’ turbo pump, operating at cryogenic (e.g. 77 K) temperatures
[15]. In this case, the gas density is being increased what should lead to a higher pumping speed at
given pump size. Unfortunately, this development was never successful, mainly for two reasons:
Firstly, the magnetic levitation at this low temperature never worked probably and, secondly, it could
be shown that the thermal-creep effect, that leads to a flow against the pumping direction due to a
thermal gradient, overcompensates the advantage of the low operational temperature [16].
Novel vacuum pumping concepts for fusion power plants
