Tuna Sandwich
In one embodiment:
  • Open 1 can Chunk Light Tuna, Yellowfin, in Broth and Oil.
  • Add to a mixing bowl.
  • Add an equal amount of bagged Coleslaw mix.
    Put the bagged coleslaw mix in a closed tub in the fridge after opening and date with dry-erase. Dispose of 3 days later.
  • Add ~2 tbsp coleslaw dressing (e.g. Co-Op Gold Coleslaw dressing)
  • Toast 4 slices whole-grain bread e.g. Dempsters Ancient Grains.
  • Clean immediately and put back:
    • mixing bowl
    • utensils
    • serving plate
1 can makes 2 normal-sized sandwiches.
Strategy for at the office
Bring loaf of bread and tuna and coleslaw dressing and coleslaw to work fridge.
Metrics
Cost (for 2 sandwiches):
$2.50 (tuna) + $3.5 (Coleslaw mix) / 3 (assuming I make one instance a day while the slaw is fresh) + $0.4 (4 slices bread) + $0.3
= $4.5
Calories (2 sandwiches):
140 cal (1 can tuna) + 150 calories (2 slices bread) x 2
= circa 450 cal.
(Wow! for such a simple meal it certainly doesn’t seem like it could have so many calories.)
To-do:
  • Coleslaw package is too big.
  • I used coleslaw dressing instead of coleslaw because it’s more freezable, but I don’t freeze it here.
    • freeze Plastic or paper sandwich bags with coleslaw mix or whole sandwiches?
    • In the past when I’ve tried to thaw the coleslaw dressing… it got very sad and inedible.
  • Vinaigrette dressings like this one are pretty hard on the teeth. Try a creamy coleslaw dressing.
