Tag yourself I’m destruction.
DeKalb County Police Officer David Rose was fatally shot when he responded to reports of an active shooter at the CDC
Why are people who write about ermine so emotive and florid? These might be my favorite snippets of text ever
https://www.genuinemustelids.org/articles/surplus-killing/
“A glance at the physiognomy of the weasels would suffice to betray their character. The teeth are almost of the highest known raptorial character; the jaws are worked by enormous masses of muscles covering all the side of the skull. The forehead is low and the nose is sharp; the eyes are small, penetrating, cunning, and glitter with an angry green light. There is something peculiar, moreover, in the way that this fierce face surmounts a body extraordinarily wiry, lithe, and muscular. It ends in a remarkable long and slender neck in such a way that it may be held at right angle with the axis of the latter. When the creature is glancing around with the neck stretched up, and flat triangular head bent forward, swaying from one side to the other, we catch the likeness in a moment – it is the image of a serpent.” – Coues, E.
https://www.gutenberg.org/files/43272/43272-h/43272-h.htm
Mustelids typically dispatch small prey with a bite to the neck or base of the skull—this is as swift and merciful as death can come in the natural world.*
No animal or bird, below a certain maximum of strength, or other means of self-defence, is safe from their ruthless and relentless pursuit. The enemy assails them not only upon the ground, but under it, and on trees, and in the water. Swift and sure-footed, he makes open chase and runs down his prey; keen of scent, he tracks them, and makes the fatal spring upon them unawares; lithe and of extraordinary slenderness of body, he follows the smaller through the intricacies of their hidden abodes, and kills them in their homes. And if he does not kill for the simple love of taking life, in gratification of superlative bloodthirstiness, he at any rate kills instinctively more than he can possibly require for his support. I know not where to find a parallel among the larger Carnivora.” – Coues, E. 1877. Fur-bearing Animals pp. 128-129.*
I need to read more of this. This is like the introduction of a dragon in a fantasy novel.
Time distribution
I was in a workshop in UK a while back and time distribution came up a lot. Two frameworks that were discussed were MRF (Micro-Research Finland Oy) and White Rabbit.
https://quantum5.ca/2023/01/24/diy-stratum-1-ntp-server-with-serial-port/
https://quantum5.ca/2023/01/26/microsecond-accurate-time-synchronization-lan-with-ptp/
While a normal PTP service provides a level of time accuracy sufficient for most current use cases, White Rabbit compensates for the chromatic dispersion of the fibre. This can be an issue for long distance fibre connections between a master atomic clock and different nodes of a network.
https://www.netnod.se/blog/what-white-rabbit-and-why-does-it-matter-high-accuracy-time-services
https://www.canada.ca/en/department-national-defence/maple-leaf.html
Read The Maple Leaf
https://www.canada.ca/en/news/web-feeds.html
Canada publishes news feeds!
https://en.wikipedia.org/wiki/Harold_Brown_(Secretary_of_Defense)
To manage defense efficiently and at the lowest possible cost along presumed business lines of management and organization is a useful standard. But there are prices we cannot afford to pay for meeting it exactly. One is the abandonment of democratic control. Another is the loss of a war. Defense cannot be “managed” like a business. But it can be led so as to preserve most effectively our national security interests.
Science cannot be managed like a business. Measles is a price we cannot afford to pay.
There are comments below about what happens when the sun gets very close to the line of sight back to Earth, but the problem is not the total power output of the sun; it is the scintillation −− the variation of power with time −− that forces the PLL to run with so large a tracking bandwidth that it can’t lock up properly.
My prediction is that the “Hacking is Cool” dumb idea will be a dead idea in the next 10 years. I’d like to fantasize that it will be replaced with its opposite idea, “Good Engineering is Cool” but so far there is no sign that’s likely to happen.
https://ranum.com/security/computer_security/editorials/dumb/
SGU #1069
1h20m Discussion of fentanyl and fentanyl vaccine“Narcan - can reverse the overdose, opoid antagonist”
“Saboxone is a mix - nalaxone (agonist) buprenorphene - prevents people from getting the high, but also helps with withdrawal symptoms, so people don’t feel as sick as going clean off fentanyl”An Immunconjugate Vaccine Alters Distribution and Reduces the Antinociceptive, Behavioral and Physiological Effects of Fentanyl in Male and Female Rats
I Fucking Love Science. Techology solving technology problems.
SGU #1051
Discussion of declining reading rates.
figures around 16% read for pleasure
Cara says there is good evidence that reading for pleasure improves metrics of anxiety, the ability to empathize, etc.
This makes me want to do a better job reading more.
https://www.electronicsdatasheets.com/download/54215308e34e247867f2bce4.pdf?format=pdf
incredible complexity. APS taking advantage of high-speed telecom FPGA cards.
