should try quinoa in the pressure cooker again. apparently 3 minutes is a good amount.
I wonder if I can double the recipe for kale soup.
- There should not be more than 16 cups cooked rice in the Instant Pot and since 1 cup raw makes 3 cups cooked we have to divide the 16 by 3. That makes 5.3 cups.
The calculation is only theory though. I have not tried that many cups in my own 6-quart. 4 cups raw dry rice are the maximum I have cooked myself without any issues and with perfect results.
I don’t see how the calculus works for kale soup, compared to e.g. some canned veggie soup.
Cycle testing now:
- 4 cups long grain white rice (
- 4 cups water
- 4 cups frozen vegetable medley
- 2 cups frozen broccoli (Co-op)
- 1 tablespoon Knorr powdered chicken broth
Cook on Rice setting.
Was a little bit mushy and some of the rice was burned on the bottom. Not bad enough to change though.
Mix in the protein:
Either
- Chicken breasts
- 3 cans lentils
- 3 cans mixed beans medley
- 4 cans tuna
- Crushed eggs
Should look into ramens.
Our results indicate significant contributions from cooking to both modern and ancestral human energy budgets. They also illuminate a weakness in current food labeling practices, which systematically overestimate the caloric potential of poorly processed foods.
https://www.pnas.org/doi/abs/10.1073/pnas.1112128108
We note thatmodern raw foodists who eat meat and high‐quality plant productsexperience such high rates of chronic energy deficiency, despiteprocessing their foods heavily by nonthermal means (38, 39), thata majority of females experience subfecundity (39).
Canned lentils are already cooked . Just rinse well and they are ready to use.
The frozen vegetable medley is not pre-cooked.
However, co-op’s frozen broccoli is pre-cooked.
the flat rubbermaid containers I’m using are about a third smaller than the tall ones I used to use. Interesting
roasting pan
The breakdown per burrito is great!
- Box of 5 dozen eggs = $8.50
- 1 1/4 lb cheese (from 2 lb block) = $3
- 3 onions = $1.75
- 3 lbs bacon = $9
- Pre-made hash-browns = $2.60
- 60 tortillas = $4
- Milk/half and half (on hand usually) = $.50
Total cost 29.35, .49 per burrito!
https://www.reddit.com/r/MealPrepSunday/comments/5tomy4/breakfast_burrito_wall_complete/
oh my god 60 tortillas for $4! can’t do that anymroe.
Wonder if there’s a way I can use frozen spinach here. the trick is that defrosting frozen veggies just takes so long…
Any canned veggies that would be a replacment for Romaine and would go well on wraps?
The great thing about meals like the chicken wraps is that they don’t need to be heated and I don’t feel self-concious eat them anywhere - I’ve just gone outside to a park bench near work (so I can run over).
tried the stovetop quinoa recipe with
- add 5 cups water, lid on pot
- add 3 cups frozen broccoli, wait for return to boil
- add 3 cups quinoa
- 0.5 cups cheap oilve oil
- 1 cup lemon juice
- set to 700 W
- timer for 12 mins (builtin)
- Turn off, timer for 15 mins
Mix. Need a bigger pot to be able to mix properly, needed to use mixing bowl.
Added the 6-bean mix, but lentils would also be good.
Not enough green.
A little bit too wet, probably from the frozen broc. Could have used less water.
Want to try with frozen spinach sometime.
Just a little bit too much lemon juice, I think. Maybe 3/4 cup would be better.
Containers are too small. Want rubbermaid 8 cup rectangular takealongs.
